I changed my 2 front wheels bearings, BUT the one on the left side was a little loose . It's crazy, because it's new... Maybe I damaged it when I put it in place.
I dismantled evrythings another time :?
This time I used REAL bearings : KOYO
When you push out the "wheel hub", it always comes with the bearing inner ring (blue arrow) :
Then you have to remove the big "circlip" to push out the bearing.
The wheel hub, without the inner ring, I (gently) used an angle grinder to remove it.
I cleaned everythings, apply some grease... and used my hydraulic press tu push the new bearing into place (it's not easy has it seems):
Then put the circlip into place, and push the hub in the bearing (using my hydraulic press) :
Everythings is in place ! Now there is absolutly no loose ! I rebolted everythings on the car.
Remember it may seem a bit loose until you tighten up the hub nut.
When I put mine in one side was very loose and had about 2mm of play in it, once I put the hub nut on and torqued it up all movement was gone. The hub nut clamps it all in place
I have to clean it a little, I think I'm going to "sand blast" it... I'm not sure about a complete paint job, It's to expensive. I'll try to fix the rust myself, I'm going to take some welding lessons
And the BBS are comming SOON !!!
Well my friend, you have one of the nicest wagons on this planet.
ps. je parle aussi le français et on est meme sur la meme forum le ae86gt.com, ça alors
félicitations
félicitations
LOL ! Tu y vas un peu fort... Yen a des 100x mieux rien que sur ce forum !
The coil overs cost me 600€ S&H included.
I fixed the rear bumper, changed the parts where the bumper is attached :
And I FINALLY bolt the rear mudflaps !
Now the bumper is straight.
I wanted 16.5cm speakers instead of the tiny 13cm ones :
Stealth !
I finnaly changed the 2 seals on the "cowl top", one is adhesive :
The big one use clips :
... To be continued
Yes I know, but it was loose when I tightened up the hub nut to.
I think I damaged it.
...Humm
...Yess !
Later the same day :
NS2 (cheap) 195.45.15
The guy at the tires shop couldn't believe me when I said the rims are for the Shuttle
ahahaa!
LOL
rims make me boner
Almost 3mm... And I'm not in the car
The rear needs to be lowered... Again...
Interior is almost done :
2km after :
Results after polishing with my electrical polisher + detailing.
Chromed hub caps.
Blacks ones... I don't know yet...
It's not over
Since then, and i've been participating in this site, and seen more of these things, it's started to grow on me.
Especially seeing how rare the color actually is......
But you just sent it through the roof... that thing looks AWESOME!
i wants me some of thems rims!
Well payed sir, well played!
I think 90% of the RT4WD (Shuttle) here have this color... 10% are white ^^
Keep Going... 8)
:shock:
félicitations
I leave the Shuttle for a little moment because I have a lot of work on my AE86... But I'll take some new pix asap
I finished my little sound instal :
In the begining I didn't want to cut the stock rear parcel shelf... And finally :
The OEM rear wires were a mess to find, and they were very very short.
8)
I really need an armrest, I find a very cheap one on ebay :
I didn't want to drill or glue...
I use big adhesive VELCRO from 3M, aeronautical quality !! Yes they use it on helicopter
would you ever sell the EK4 wheels?
