Little Blue Wagon Build
My tale of woe starts with a now non-functional minivan. Things happened, mistakes were made (all mine as far as I know) and now it doesn't run. I need dependable affordable transportation for my >60 miles daily round trip commute.
My brother is bam-bam.
So as you might expect, I've been looking at Civics for weeks trying to find a fifth or sixth gen sedan with reasonable miles for a reasonable prices. Finally my funding falls into place and I wrangle bam into inspecting used civics this past Saturday. (Who would know better?) After a late start and not being able to get in touch with sellers (they do want to sell those things, right?) bam reloads the search on Craigslist at about 11:52AM. At the top of the list, posted at 11:46AM is an '89 Blue Wagon, Automatic, reasonable miles, reasonable money. He calls and we get on the road across town. First car we look at, I buy after bam says it worth what's being asked.
Today we reconvened at the BamTech Speedshop and start cleaning the old girl up. She had been parked out in somebody's yard for years while her owner when to Africa, apparently. Ah pinestraw. that dang stuff works its was into every crooked nanny, er, hookin granny, ah, nook and cranny! The things that need tending are common on these according to bam so I won't rehash them for you. You all can probably spot them in the pictures!
I gave her a pretty good wash without powertools but bam pointed out how much more effective the pressure washer is and then things really started getting clean!
Here bam's pulled out most of the interior so we can get both the seats and the carpet clean. Even Pebble's was helping and she's not directly related to me or nothing!
Bam tells me that this motor has been swapped in and is not original to the car. Who know when or why the valve cover got painted silver.
From the bam-bam collection we assembled the right number of uncracked lights, trim pieces, etc. The guy we bought it from had gotten the car running and it certainly ran highway speeds on the way home. The interior was mostly intact and accounted for so we are just going through and cleaning out twenty years of somebody else's dirt for a fresh start. Truthfully I probably could've driven it the way it was but if you know bam you know he does not leave things like that to chance. With him doing the hard work and me filling in with unskilled labor I expect to have what I've seen called a 'twenty year old new car' when he's done with it. You can't beat that for the money.
Right now she'll be rolling close to stock but on the future wishlist are:
manual transmission
stereo head unit
a rear speaker solution
tinted windows
roof rack
upgraded rolling stock
Bam has more pictures but I don't know if he'll post them or clue me in on where to find them so I can. He can certainly chime in on what he'll be doing under the hood or I can summarize. Of particular interest or environmental systems (AC & heat).
«134567…13
    looks pretty good.
    If you need blue interior pieces don't worry about that.
    Bam has my interior sitting in the back of the shop so I'll be donating my blue interior for the next person.
    We are going to do an interior swap on mine.
    I got the text yesterday with the picture of your wagon.
    I was like oh hell he bought another one.
    I knew he said you were looking.
    Congrats on the wagon.
    Awesome, cant wait to see what she looks like in the future.
    bam-bam wrote:
    Yep, brother needed an economical family-friendly ride, so guess what I came up with...
    The car's pretty straight, just dirty and neglected.
    Needs a hood, we'll have to search for a good one.
    At least she's in good company!
    bam-bam wrote:
    has a JDM d15b non-vtec swap in it. No smoke, new headgasket etc. Supposedly due to faulty fan switch. I drove it home about 40 miles hard with no issues, hopefully that'll continue.
    Had several broken lenses. Replaced outer taillights, one hatch light ,right headlight, bumper light, etc. Cleaned things up a bit while we were there
    Installed the elusive rh mirror, too
    And just generally gutted and washed the works
    Next we'll reassemble the interior and fix the AC.
    rbwdriven wrote:
    looks pretty good.
    Good to know! Yeah, without the support of bam-bam and the community this would much more spendy. The interior really only needs a couple pieces, as usual those worn by the driver day in and day out. This one isn't quite bam's (close) but I like his styling choices so it'll probably end up looking something like his... if he had two kids and needed a pretty solid daily driver instead of a high performance go-kart with cargo handling properties, lol!
    Thanks! There's no reason not to have fun with the daily driver.
    Well, so far today I've hooked up the heater core (no leaks, wonder why it was bypassed?), removed and cleaned the AC evaporator. Reinstalled and now vacuuming it down. Will put the dash back in while I wait. More pics later...
    I cant believe half the things people have done to our poor wagons. What did you use to clean rear seats?
    Pressure washer and sunshine & fresh air to dry.
    Purple Power plus a pressure washer. Say that five times fast!
    The best thing you can do for your wagon's airco is to remove the evaporator and clean it. 20 years of unfiltered gack sorta restricts the flow. That's why your blower sounds like an airplane taking off, but feels like a funeral parlor fan.
    While you're in there, make sure that the condensate drain tube is clear.
    Made a quick trip to get retro adapters and 134A
    ...and after letting the system stay in a deep vacuum for an hour and a half, charged about 30 oz. of refrigerant.
    Seems to be working!
    Also put the dash back in and did some more cleaning. Hopefully tomorrow we'll put it all back together. The seats are mostly dry, another day in the 96degree sun oughta finish the job!
    Sweet!
    Future wishlist:
    manual transmission
    stereo head unit
    tinted windows
    roof rack
    upgraded rolling stock (something in a 15" alloy Honda wheel)
    center console armrest
    cupholders
    rear cargo cover
    welcome to the worlds of civic wagons! i never knew bam had a brother! lol. hope to meet you and "little blue" one day. :)
    He may have been ashamed because I only drove American made vehicles, lol. Live and learn!
  • BIOHAZARDBIOHAZARD Wagonist
    great little blue wagon you have there. cant wait to see it evolve.
    Yea, I'd hide my families poor life decisions, too. My dad drives a Ford. :shock:
    I have an a/c to put back together and have a ?. Do you have to pull the dash to get the evap box back in or can I just pull my glove box out? Sorry maybe a dumb ? but trying to save some time.
  • jb2wheelsjb2wheels Wagonist
    Are the fenders really as straight as they look? Nice car.
    I had my evap in and out through the glove box.
    lots easier with dash out but.
    you can remove the glove box and the support bar that connects both sides of the dash that the glovebox mounts to.
    that is how I cleaned mine.
    Yes, the fenders are that straight. Just the hood damage and a few door dings.
    ^^They're right, just remove the glovebox and support. The evaporator is about the easiest one I've ever done, and I've done a mess of 'em...
    So today (day 4) I went for the emissions test.
    Failed, but not too badly. High hydrocarbons and CO, but coded for O2 sensor as I pulled into the lot. Changed that and the ECT, plus plugs and wires, fuel filter, ANOTHER used starter, new battery.
    Retest manana, wish us luck!
    Thanks ya'll and goodluck on the tests tomarrow. I cant wait to see where this goes.
  • Good luck man. I always like the blue on blue wago's.
    While bam was busy up front I was buttoning up things in back.
    Reassembled the spare tire area with the standard things. It didn't come with a jack, jack handle, lug wrench, etc. We've assembled and almost complete set from bam's collection. Massaged the tire well lid closer to flat.
    Looking good, did it pass emissions? I also just realized it has power steering? is it an rt?
    DX Automatics also have PS
    Correct, and also a larger brake booster.
    No, I didn't make it to the emissions test Friday. I came home from work and started the car to warm it up (even jumpstarted the lawnmower with it!). Went in the house to baptize a teamster, and when I came back out it was no longer running!
    Wouldn't restart, was flashing code 15 (ignition signal), so I replaced the distributor with a used one. That fixed 'er, but not in time to make it to the shop for my retest. Will do Monday, cross your fingers.
    Yesterday I replaced the hood latch release cable...now I understand why they stay broken. Major PITA.
    Also found that the oil pan/drain plug is stripped :evil: The ONLY leak this car had was a drip from the plug, NOW I know why. Oh well, if I can't fix it, I have spare sumps.
    On the list for today: Left CV axle (yes, I have those laying around, too!), and whatever it takes to sort the oil drain.
    On the list for today: Left CV axle (yes, I have those laying around, too!), and whatever it takes to sort the oil drain.[/quote:3qj81r7a]
    Hood cable PITA!!! LOL.. Yeah it is...
    I was washing my red wagon the other day while it was running.. Clean the Engine Bay, Clean the Wheels, Cleaned under it (as best I coud), Dried it off, went in to get the windex... When I came out, it was sputtering & then Died.. Could only get it to restart under full throttle & had a really bad miss then.... Distributor seal! These are important people!
    On the list for today: Left CV axle (yes, I have those laying around, too!), and whatever it takes to sort the oil drain.[/quote:1b40rzdu]
    You learn something new everyday, I had no idea. That sucks about the drain plug, Alotta those oil change people are idiots( I know, it's what I do for a living @ the moment) always fixing what someone else messed up. Good luck tomarrow.
    Wish I had a Bam Bam for a yoda.lol
    A little update:
    Yesterday (Sunday) I managed to fix the oil leak. I replaced the plug and straightened the sealing area on the pan. I don't know how many drain cycles it will last, but it's dry for now...
    Replaced the left CV axle with a used one I had.
    Fixed the timing belt. You may remember that the previous owner had just replaced the headgasket- he had the belt off by one tooth. No wonder I couldn't get the timing set right!
    While I was in there, adjusted the valves. It's MUCH quieter now.
    I was shooting for having it ready for an emissions retest today. When I fired it up I noticed that the radiator hoses were warming at the same rate... CRAP, no thermostat! Cold running engine is a sure recipe for running rich/ high hydrocarbons. It was too late for parts by then, and I was fed up, so I went for a motorcycle ride!
    So after work today I picked up a new tstat and gasket. Installed that, warmed 'er up, and passed the smog test. :D
    Now AC is leaking, may require a compressor. Of course, it's a Matsushita and my spares are all Sandens :( I have a suction line ordered for tomorrow, I think that's the leak.
    Once we get the AC cooling reliably, all that remains is radio installation. I'm short the DIN surround for the console.
    bam-bam wrote:
    A little update:
    Small pulley one or large pulley one.
    If it is the small pulley one. I've got a spare.
    Rich
