EE/EF/DA Interchangable parts (Please Add)
                    CAN'T KEEP UP WITH EVERYTHING, READ THROUGH ALL PAGES, YOU MAY FIND WHAT YOU WERE LOOKING FOR.  IF YOU DON'T FEEL FREE TO ASK, RESPONSES COME PRETTY QUICK.
trying to make a comprehensive listing...feel free to chime(yes and no), i'll do my best to keep it updated, mods feel free to help with updates. maybe we can get this to a sticky. lets see what you got.
dizzle quote "to add to the confusion i will simply put SH3 for hatchback and SH4 for sedan compatible parts with the wagon"
EXTERIOR
fenders - no
headlights - yes year specific
corner lights - no!
bumper lights - yes 88-89 will swap with any year wagon
bumpers - yes with mods
doors - no
window glass - no
side view mirrors - no
door hinges - SH4
exhaust - no
hood: no
tailgate: no..duh haha
rear bumper: no
rear fogs: SH3 and SH4
tailgate spoiler: no
INTERIOR
steering wheel - yes
dash - yes with mods
door cards - no
heater/ac setup - yes
main relay - yes
fuel pump - yes
power door locks: SH4 (stay year specific) as long as you use SH5 rods and stuff.
seats: mixed info, i believe as long as you stay year specific you can use SH4 directly..?? and if you use wagon pans SH3 will work as well.
center console: no
console between the seats: no (so they say)
seat belts: i believe yes SH4 as long as you stay year specific... but then again, not confirmed.
gauge cluster: SH3 and SH4
cluster cover: no
HVAC: SH3 and SH4
carpet: no
SUSPENSION
lca - yes, 88=88 & 89-91=89-91
shocks/springs/coils - yes, da will also work
strut tower bars - yes
cross brace - yes?
sway bars - yes
trailing arms - no, wagon arms are beefier
rear LCA: all Civic 1989-1995. these can also be swapped into an '88 if you use 89+ struts
front end suspension compents: SH3 and SH4
rear trailing arm: no
BRAKES
discs/drums - yes
rear discs - can be done, not easy, recommend kit available in marketplace
EXTERIOR
fenders - no
corner lights - no!
doors - no
window glass - no
door hinges - SH4
exhaust - no
hood: no
rear bumper: no
INTERIOR
door cards - no
main relay - yes
fuel pump - yes
center console: no
cluster cover: no
HVAC: SH3 and SH4
carpet: no
SUSPENSION
cross brace - yes?
sway bars - yes
BRAKES
discs/drums - yes
Negatory.
http://www.hondacivicwagon.com/board/viewtopic.php?t=3961
fenders - no
corner lights - no!
doors - no
window glass - no
door cards - no
door hinges: SH4
exhaust: no
hood: no
center console: no
cluster cover: no
HVAC: SH3 and SH4
rear bumper: no
carpet: no
dunno what else there is for now.
things still haven't been mention: brakes, sway bars, cross braces, strut tower bars, a/c&heater units......
i mentioned that :P
-brakes are all the same, just not for the Standard hatchback.
-front sway bar im positive is the same for all EF
-strut tower bars will also work, front and rear
anyone got more?
-DA spindles/brakes can be used for a simple bigger-brake upgrade. also the M/C and Booster can be used (together though)
-CB accord front lips can be modded into rear lips.
-CB accord wagon cargo cover can be installed into a civic wagon, just not the absolute nicest fit, though its still may be better then nothing :P
I accomplished bolting on a 91 CRX front bumper and cover with no mods. There was some pushing and pulling, but it bolted right up. The hood latches just below the upper lip and to make it look perfect I will have to probably mod the old upper lip which removes to fill in minor cosmetic gap.
Everything looked aligned alright from what I could see (dark).
I can also confirm the the swapping out the seats from the crx worked.
I took the seat foam and swapped them, the seat back swapped out no problem.
the parts store gave me rotors and they rubbed the outer side of the caliper bracket real bad and i went back to get new ones and i found out that they gave me 2wd rotors and not 4wd rotors. so i believe that any 2wd rotors will not work on 4wd wagons.
Are the black trim piece under the window and the plastic cover on the bottom of the windshield interchange between our wagons and EF's?
oh and also the mid trim pieces on the doors?
mid-door? No.
Base of windshield? I doubt it. Probably not.
Not the same...
wheels? yes
light bulbs? yes
