Fool's Gold! Size DOES matter.
1…6791112…42
    That's going to look cool shaved down like that!
    My mind went to hell on that comment.
  • 3rd4ce3rd4ce Council Member
    bam-bam wrote:
    ...now I have no place to mount the prop.valve, power steering reservoir, air filter box...
    man u dont need a damn air box grab a snorkel ( so i can c how U install it and do the same ...)
    as for the power steering reservoir could it b rotated to the side of the inner fender still behind the drivers head light.....
    lost me on a prop.valve :roll: what is that ...???
    Prop valve for proportioning the brakes.
    Little silver thing on the passenger side shock tower.
  • Wouldn't you be able to keep all the hard line in the original spots and just use longer stainless lines to the calipers? Or did I miss something?
    Yes, but I've removed the place where the proportioning valve was. I'll have to relocate it a little lower. Really the least of my problems atm.
    SMOKIN' PROGRESS tonight!
    literally :oops:
    while welding this piece, I got the firewall a little warm
    guess that's what I get for welding on a fully dressed car, huh? Look what I did to the blower housing:
    It's coming together slowly
  • Whew ^^ that got a little warm haha... good progress though!! i could read this thread over and over lol
    Good job man!!
  • AbideAbide Council Member
    dude....its called a FIREwall, you should have know better.
  • SiRgeSiRge Wagonist
    Just remove all the power steering stuff and replace it with an MR2 electric pump and reservoir tank. Means you can mount it where ever you want and take a *tiny* bit of stress away from the engine.
    +300 more baller points obviously :lol:
    I'm sure you have a spare blower assembly?
    I spoke with Pat and he said you were making a trip to the metal super market.
    I guess you did by looking at that.
    No he doesnt have any spares i got it from him @ Honda Fools meet ( it gets cold up here n Virginia ) LMAO
    where is this metal super market .. i need a piece of steel to support the winch and bolt to my cross member ...
    pretty sure there wasnt anyfire just a lil smoke ...
    think Bam is in a league so much higher than Baller Points...
    oh wait maybe he is building this one for STANCE... or parking lot profiling @ the friday night local fast food meets .. :lol:
    Yes, I should have known better.
    Yes, I have spares (duh)
    Yes, I did go buy some steel.
    Made some strides tonight...
    Managed to get the other side done with no flameage. In fact, I stripped the firewall first this time :lol:
    pattern first with cardboard, then transfer to metal
    Got the tops done, time to move underneath again!
    ^like it was made that way....!!!
  • Is the drivers side one going to clear the alternator?
    I cant remember how close it is there with a Dseries
    if it doesn't, its not big challenge to THIS GUY.
    I'm not worried about the alternator, the whole engine will drop 4". Alternator should be below the "frame".
    I AM concerned whether the supercharger will clear the firewall and apron. And how the steering shaft will work...
  • Ohhh I see what you are doing, I assumed engine was staying in the factory position but then I guess drivesaft angles would be unworkable
    You should have a delivery tomorrow.. ;)
    I might have to stop by on my way down to see the progress in person, next Saturday... Except I am meant to be at a Wedding... :(
    Every time I see this I just go wow.
    Bam totally nuts dude.
    How are you making the bends? Have you a brake that will handle that gauge steel?
    I'm betting it has a lot to do with wood and a vice..
    What have bam's bad habits have to do with it?
    ha. rbw's right, though. I used a viSe.
    I thought that was meat and a vice :)
    I'm on a tear now. I'm ready to see this thing on its feet again!
    Cut out some frame/apron extensions
    spacers for the crossmember drops will tie into these plates (3/16" steel)
    mount is just barely tacked up there to give me an idea
    Note the forward end of that reinforcement hangs way out- that's about 3" beyond the bumper. Oughta give me a good foundation for whatever silliness I decide to add to the front. What I want is a plate bumper if I can build it light enough.
    Here's my sketch :)
    this is coming along really quick.
  • bam-bam wrote:
    Here's my sketch :)
    Um... Is that a rocket launcher on the side... like on an attack chopper? ...cause that would be sweet....
  • I thought it was a golf club and ball :/
    Either that, or he's planning on playing Polo with the car...
    I cant wait to see this beast in the air
    Hmm, rocket launcher....
    Naw, that's just a side view of the bumper.
    Saturday fun: started out cutting parts from the donor to mount front crosssmember
    Those extended plates ended up getting clipped off, didn't work out. Partly because I wanted to have the stock bolt-on locations in case I have to run a traction bar.
    That took up a good part of the afternoon, then ZCPower_R came by in his SCed wagon. Good thing, too!
    see where the blower pulley is? 4" down from there...
    that oughta clear it!
