Fool's Gold! Size DOES matter.
1568101142
    Welded up some pedals tonight-
    devised a new gusset, used 2 quarters of a 1" flat washer
    not for this car actually, but for a friend.
  • i did mine when they were out the car i braced them as well
    Game on!
    Got her back inside tonight.
    and started dismantling to work on the front lift
    I'm still not clear on how exactly this is going to work, but I have a couple of ideas. I've found that I just have to start cutting.
  • josephisjoejosephisjoe New Wagonist
    i need a bam in washington.
    let the front games begin
  • I love it, a Wagovan stump jumper, my question is will the drive line and half shafts be able to turn the larger tires without breaking, might want to check around to see if there are any stronger one that will fit.
    Dude, we'll find out when he finds out, lol. Who else could he ask?
    It's a good question, but I'm not much concerned on that score. I've seen several RTs on here with more power and torque than I plan for. The trick is not to snatch on it. Shock load is what'll get ya. I'm trying to decide on a clutch setup to get the thing rolling :lol:
    Of course, I have 4 trannies, 2 diffs, 2 drivelines, 3 sets of axles....
    And the tires won't be all that huge, 29-30" diameter.
  • Subscribed... Bam always has the most interesting builds. Props for going where no other has trekked :D
    So amazing! I will follow this thread! Keep us posted Trev!
    Well, got started on the donor car. Cribbed it up as high as I could and began the demolition.
    funny how you can't take a picture of just ONE wagon around here
    tuckin' 14's yo...
    Did some exploratory surgery- cut it deep and wide
    Dad's holding it up so I can get a visual
    Then I started marking up the real deal. Still some pondering to do before I fire up the saw on this 'un.
    I'm going to try and mold it all back together, so plotting the cut to use the existing metal.
  • 3rd4ce3rd4ce Council Member
    :mrgreen:
    very nice progress...
    u should measure that door handle i think u have all the low guys beat .....
    but u would b worse than hoss going over speed bumps draggin those truck nuts :lol:
    scraping sounds like me up till 2 weeks ago.
    Got sick of scraping going round corners.
    I thought I almost had to get out and push in the church parking lot.
    I'm looking forward to seeing this thing.
    Well come on then!
    Got aa big pile of junk that needs to go back on the car :shock:
    And a redneck bamtech strut bar
    actually that's just a jig I threw together so as to be able to get the towers back in proper relation to each other- same distance apart etc.
    So here we go, the big whack :?
    Gonna have to notch the frame rail a good bit to clear the UCA and strut
    but I think it'll all blend well.
    This is about as far as I want to go until I get the other side to the same point, then I'll confirm positioning and sew it all up.
    Trev,
    You truly are the yoda when it comes to these wagons.
    I never would of imagined all the stuff that could be done to them.
    But seeing your work is awe-inspiring.
    Just a little more cutting tonight.
  • You're Nuts.
    I love it.
    Keep up the good work bam!!! Any updates?
  • I can't remember if you ever came up with a solution to the crazy CV angles that you will get in the front. Are you gonna drop the engine and trans mounts down as well? Or is there some other solution in the works?
    EDIT: never mind, i just found the answer to that. Page 3.
  • hey bam-bam . i joined up a few weeks ago . but we met back at summer i.a. last year before i bought my wagon . you were there with the camper . i was there with the eg 4door that looks mostly stock with the B16B gunmetal 4 door on the spoon sw388's and the itr 5lug swap .. dont know if you remember . but i was talking to you about getting a wagon . well i sold the sedan and bought one have a lot of work infront of me ...
    and seeing your new project and your older ones gives me hope .. along with the other builds on here ... if you would message me where i can give you my number i have some questions to ask you .
    Thanks. No updates, spent the weekend working on other projects. I did have a good welding/fab consultation with Porterwagoneeer, though.
    So, progress but not tangible results :)
  • DRMORTY wrote:
    You guys got to see what I am selling Now
    1993 Civic SiR Pickup!!!!
    http://www.tamparacing.com/forums/cars- ... truck.html" onclick="window.open(this.href);return false;
    I want it!!!
    i dont know whats scarier the fact that i have a 83 dodge rampage in my back yard and an eg shell as well .. or the fact some one beat me to an idea that i had been tossing around for about a year now that i see what it would look like im going for it lol
  • Looks like a very unique build, can't wait to see the finished outcome.
    Well, I finally got some "me time" tonight. Positioned the left tower and started trimming the remaining metal to fit
    Put a few more tacks on this side as well, and started patterning the stiffener I'll use
    trans mount will weld to this plate 4" below the original location
  • this is what i like about bam's work.... he starts some thing, and then he FINISHES IT! Most people who would tackle this sort of problem would give up halfway, or at least get lazy and start cutting lots of corners. Good to see someone stick to it til the end.
  • bam my hats off to you .. im good but not that crazy lol if you need them i have some 15 inch bobcat tires there 30 inch tires and i can put 1000 bucks says you will never ever have a flat tire lol
    Hell, I have to finish it now. if I don't it's just a big pile of scrap with a big pile of my labor in it!
    I didn't get to work on it much through the weekend, had other obligations. I did manage to get in a little more cutting and folding, roughed out a pattern for the shock towers.
    It's going to look crazy with them shaved down like that...I like it!
    This is the same piece folded backwards- it'll work for both sides :)
    That's going to look cool shaved down like that!
    ...now I have no place to mount the prop.valve, power steering reservoir, air filter box...
