Integra rear seat conversion
Integra rear seat swap..
I finally had some time to swap materials for the back seat.. the passenger rear material from the teg was pretty much a swap over, the driver's side required a 1 1/2" piece sewed in to match the width.. headrest cushions and material went onto the civic shafts pretty easy
Looks so much cleaner with matching seats.. now for the doorcards and armrest
also, one of my biggest concerns is keeping the OEM seats because they lay flush and flat when all folded down. do these do the same as the stock seats?
any photos of them folded down?!
thanks again for finally doing this swap. finally we have options!
looks clean:)
thanks!
Nice work by the way.
Well the problem you'll run into, if I understand the install correctly, is that you will have to sew extra leather onto the seats to fill in some of the gap. I'd think a cloth seam would be a little more forgiving than a leather seam when it came to looks.
Looks great by the way. I'm planning on doing this with Evo 8 rear seat covers as soon as I get a set of fronts (already have the rears).
The Integra material needs to be modded to fit the wagon seats.. I would stay away from leather, I had leather in my 1979 civic... (too hot in the summer) I've now re-wrapped the stock back seat with 2003 Civic Sir material.. I was going to install the 03 Sir fronts, but they are just physically just to big, So I've stripped the material from the fronts and I'm going to re wrap the current porsche seats that I have in it..
once I find the teg material to match my other 89 wago I will take progress pics...
Cool, keep me/us posted on this. I'm hoping to be picking up front DA seats next month and after seeing this, I might have to take the rear seats as well!
Very cool job on this though.
putting buckets in the rear would be difficult. You would have to have a low bottom cushion in order for it to work. I thought about the '93-'96 prelude interior.. split buckets and console front to rear, but I never got around to trying it
Are you using hog rings to secure it to the metal bars in the foam. I guess ive never taken rear seats apart. I would think it would be like the fronts where you have to use hog rings.
For the top part of the seats I did the project exactly like on this thread EXCEPT I didn't cut slits for the headrests. I don't have another set of integra headrests so a simple flat top it is.
By hog rings, I'm guessing those are the copper rings that came from the seats? I used everything that came off the seats.
Now here's where things start to take a turn.
So I was thinking about doing the whole split seats thing for the bottom part, but I wanted to keep the "feel" of the original integra seats. They seemed to sit better being they were a bit lower, so I just used the one piece seat. I just mounted it on the bottom half of the wagon frames and bolted it down with some carriage bolts.
Don't get me wrong, I'm no expert at this, but I just wanted them in. There are exposed carriage bolt tops, but it isn't too bad (they shock the shit out of people sitting in the seats though haha). I managed to get the back part of the bottom seat frame on and cleaned it up. I shortened the threaded side of the bolts with a hacksaw and I'm going to put some rubber putty on the exposed flesh cutters.
Overall, I love my version of the seats, the only downside being I can either have the seats both up, or both down. It's not really a problem for me as I never really haul giant things in the car.
Heres a picture of my seats as they are now.
Evo rear bench seats did not have a split, nor were they designed to fold down due to the additional chassis bracing behind the seat , plus a rather large armwrest solution in the middle that sported some absolutely amazing cup holders (knowing this as a former Evo owner).
Would love to see how you solved these issues if you were able to make it work.
