will the JDM integra type R brake booster and m/c fit?
949
Senior Wagonist
hey guys i got my hands on a set of brand new JDM integra type-r booster and m/c for the 91 4wd wagon. im curious if it will fit?
has anyone done this?
any pics of theirs installed?
also have the skunk2 intake manifold as well. i dont have an issue removing this but would like to see if it will fit along with the longer booster that i want to put in.
Yes and No. The master cylinder mounting studs on a ITR/CTR/Si booster mount on a horizontal plane, The 88-95 mount on a diagonal plane.
So If you're using you're 91 master it won't work, If you have the itr master is "should" work, but the break lines need to be bent into position. And the vac port is going to be on the wrong side.
here it is.
i got the matching m/c with the booster. i am worried if the booster is kinda long. it seems to be much larger than the space the are i have.
EDIT, you must have stolen that pic. That one shown is actually a early GSR. Also note the large (usdm) abs fitting.
he said its a JDM integra type r booster and m/c
im not familiar enough to see what it really is. im just trusting the seller.
That photo from this thread http://k20a.org/forum/showthread.php?t=85851&page=13
is what I was getting at.
http://www.ebay.com/itm/260958514673?it ... 23&vxp=mtr
what year and model u.s. integra?
so between 98 ITR, LS, GSR is the ITR still the best choice or are you saying these three are still the same (1 inch ABS)?
do you know if the brake lines are on the same side as the stock civic ef lines?
if not which model and year integra should i look for? (going with 1 inch with same booster)
I'm not sure about the brake line positions. I know I had to do some rerouting in one of my EG's, but I haven't tried to fit one in my wagon. I am running a 15/16" master cylinder on my setup from an EF Civic EX. Your thread is making me wonder if I should bump up to a larger brake booster.
viewtopic.php?f=5&t=9269
well so far...
i have sent numerous ebay pm's to the seller with no reply back, before payment there was constant messages back and forth about the details of the item, shipment, etc.
i have checked the mail box daily and no package.
payment in full was since feb 2012.
item was promised to be recieved within 4 days. its been about 21 days. :roll:
It shouldn't have the large usdm abs fitting.
I'll take a pic of mine tomorrow and point out what I had to bend. Its on a eg but the lines mount in the same spot as a ef.
Well the rear line is direct but the front moves to a top mount. The original location is like a 60' angle so you just need to massage it a little to fit on top at 90'.
Now that I think about it the booster itself is a good inch thicker so you will need to massage both lines.
No
USDM has the front line on top and the rear on the opposite (pass) side
this. paypal has a certain time frame before you're fucked.
Here is a photo of mine. jdm itr
Still curious why you think you need a a 1" mc? With the rear drums I really don't see any improvement. Unless you are going to swap those out somehow. Will need the 40/40 ppv as well. But for the money spent, a set of aggressive pads would have been cheaper and more effective than the mc/booster swap.
i would like to get a new version.
i have a custom setup made for the 4wd. its an integra type R front and rear disc conversion with a 5x114.3 lug pattern.
1 inch will definitely help me out.
do you think that a skunk2 intake manifold will clear this?
I your talking D motor i have had issues running the Skunk2 manifold and not hitting the firewall. I've had to use flat bolts on the idle control valve and i have had to use an adjustable front transmission mount to pull the motor away from the firewall. I have considered removing the control valve and relocating it somehow.
im not talking about the skunk2 manifold hitting the fire wall.
im concerned about the skunk2 hitting the bigger brake master cylinder and the bigger booster.
is the LS an ABS unit or GSR an ABS unit?
hows are the lines? will it bolt up, or will an adaptor be needed?
