EE/EF/DA Interchangable parts (Please Add)
2456712
  • klumklum Senior Wagonist
    good info
  • Says that headlights are interchangeable, year specific. Will any 89 Civic/CRX headlight work on my 89 Wagon?
    Yeah just stay USDM.
  • Cool thanks Haydz...
  • are all 88-91 wagon doors interchangable. i.e. 88 wagon doors on 90 wagon?
  • Great thread, lots of good info here.
    yes
    MondiVTEC wrote:
    yes
    I would think so, with one question: Do the '88-9 doors have the latch/switch/harness to activate the seatbelt? I know all that can be swapped around, just something to consider.
    if you use an 88-89 door on a 90-91 you will need to swap the latch w/ wire harness from the 90-91 o the 88-89
    (and vice versa)
  • Anyone know if radiators are interchangeable? I would think there wouldn't be any issue, but just thought I'd check before looking for a used one...
    radiators are the same for any 4th gen civic/crx. automatics have two extra nipples however, but those can be plugged.
  • Cool. That's what I thought, but figured I'd get a second opinion before sacrificing the one from the CRX for the wagon. Thanks man.
  • Couple (possibly stupid) questions: Are the vents in the dash, front mudflaps, inner door handle and plastic door locks interchangeable with the ef sedans/hatch? and will the DC2 Integra center console fit like it will with ef sedans/hatchs? Thanks for any help.
  • B-RadB-Rad Wagonist
    This is a good list. Thanks for posting, it has helped clear up some of my questions.
  • Good info!
  • Yo guys can the civic hatch or sedan speedo cable fit also the 91 wagon that i have?
  • would an 88 windshield fit a 90
    found a nice one at the yard
    mines cracking more everyday
  • TofumanTofuman Band Wagon
    Great info! This will come in handy for me when I aquire my wagon!
    speedo cable- yes
    windshield- yes
  • grassy ass
  • civic si rear spindles(lil modification needed)
  • My rear driver's side upper door hinge broke due to rust and now my hatch opens up sideways :evil:
    Does anyone know if the EF hatch or any other honda/acura has the same hinge as my wagon?
    Any kind of info would be much appreciated :D
  • hood hinges; are they interchangeable with the ef sedans and hatches?
    edit: looked on car-parts and I guess they aren't.
  • what about the rear bumper supports. can i use the ones from
    a civic 4dr on my wago. i have a 91 2wd if that helps
    I wish they were. I need a un-dented hood, lol.
  • So no interchangable fenders for 88-91 huh. Good info. I need to find a drivers side fender now.
  • won't changing fenders effect what corner lights you need to be using?
    No, just change the plastic clips im the fender to the other style.
  • To my dismay 88-89 wagon vents are not interchangeable with 90-91 sedans :(
  • anyone know if a 4WD gas tank will fit into a wagovan? i sure hope so...
