Fool's Gold! Size DOES matter.
13468942
    I've got the rta tool if you need it.
    Awesome, it's getting there, cant wait to see this beast complete.
  • Why fools gold now? Your coming along fine been watching for awhile now. good work man this is gonna be awesomesauce man.
    Well, the car is gold, and I'm a fool! It just struck me funny.
    I want a vanity plate that says PYRITE
  • got ya that works! What about pyrite?
  • Great stuff bam. i may just have to drive my wagon out there and we can go play in the cuts!
    (as soon as i get mine back on the ground and rolling again)
    Well come on then!
    Nasty!
    both of the assemblies on hand looked like this, yuck. The inside of the tanks did, too! Here's the new Walbro setup
    Luckily I have 4 tanks to choose from. This is the one from lil' ghost/pebbles old blue waggy. I gave the pump to a friend in need awhile back, but the tank is nice inside
    That's just surface oxidation- it's been sitting around open for awhile.
    Decided against this crusty gauge sender as well.
    ready to install tank- it has to go in before the rear diff I think
    Here's Dad whittling on the RTA bushings
    Got 'em ready to install, too
  • Bam, what'd that RTA cost you, that's exactly what I think I'm gonna need.
    $40 shipped, but they're a big PITA. If I had it to do again, I'd buy the preassembled ones for $95.
  • That's a big cost difference, what's so hard about putting them together?
    You have to cut the OE ones apart and clean ALL the rubber from the shells and the shafts. Of course the first one took hours, the second about 45 minutes.
    Air body recip saw with some grease on the blade worked for us.
  • Wouldn't it have been easier and way more fun to just burn it out? :). That's what I usually do with bushings lol. Or is burning them out of the question?
    My oxygen tank was empty lol
    Super bummer!!! I'll have my buddy at horsepowerfreaks order me a set tomorrow! My suspension might actually be back under the wagon next week.
  • drool.......
    Bam I've got the press tool if you need it to get them in and out.
    Thanks, I got it.
    :D :D :D :D :D :D :D :D :D :D
    Ha! I'm grinnin' like a mule eatin' briars!
    It worked!
    ^^That's fully extended, with the wheels juuuust touching the ground. Axles still have some end play :)
    Now sitting on the suspension
    Got some positive camber, and haven't set toe at all yet, but looks good. Now that's some wheel gap!
    Dad says I can fit a 30" tire easy :twisted:
  • 3rd4ce3rd4ce Council Member
    now Scrappy has a real big brother to look up to...
    u gotta call it Scooby Doo
    :lol:
    Holy Crap.... :mrgreen: :mrgreen: :mrgreen:
    You did that fast...
    You just want to barrow my suspension spacers and make it a little higher? I should be able to fit them in a flat rate USPS box..
    Put the ass down on the ground and give us a measure on the stock RT wheels.. I gotta know how high it is...
    You need a new users name.. BAM-ITS-DONE
    That measurement IS on the ground with stock wheels and tires, AND with the front still unlifted.
    (I mean the 37+ in the post your measurement thread. That was with the front sitting on the ground, no drivetrain. )
    Yeah, send the spacers, I need 'em for the front. I'll have a machinist buddy copy 'em.
    I don't think I want any more in the rear. Everything goes back together well, axles are still ok.
    The only actual modification to the suspension is that I moved the spring perches down 2". Same as adding a 2" spacer.
    And No tires and No suspension spacers..
    So, you want me to send you just 1 spacer or 2?? I can do this on Monday..
    What does your dad think? Thinks your losing it, right?
    That's with 2" suspension spacers, effectively. I dropped the frame 4", but dropped the strut tops 6. Pay attention, boy...
    LOL... Ya.. I caught that..
    so, what was the starting measurement? what is the overall lift? did you get a full 6 or more?
    :oops:
    ummm...idk. didn't measure "before". but yes, at least 6"
    Get a measure to the top center of the rear wheel well.. it shouldn't change too much with the front down & I measure mines stock height... Looks like you got more than 6..
    Holy crap Bam.
    You did it.
    I really need to come over now.
    Currently on 205/60/15 it's 32 1/4 to center of the rear arch.
    Poll of 4 other stock wagons here averages 24" (23-25, depending on load :lol: )
    My DD wagon lifted slightly on 205/60/15 is 26 1/4
    I took some pics, but have mislaid the camera
