UPDATE on LIFT KIT - NOW MY REAREND is LIFTED ( Last Page )
So Bam Bam & I were talking about how to lift a Wagon... We both have so crazy projects in mind..
Another user on here was also trying to develop a lift kit for wagons.
I saw some strut lift kits for coil suspension trucks and it made me think... That is what we need!!!
Just so happens my New Brother In-Law runs a CNC machine shop.. So, I spoke to him about this idea, and he said he should be able to make what I need.. So, I brought him a strut & cap.. ( back in Feb, but he is really busy making parts for places like NASA, so mine took a little longer than his 1 week estimate )
The Original Goal was 3"s and so the Prototypes was to be a 3" set.
Yesterday was my birthday ( yayy, but not really happy about birthdays ) but then, @ 9:30 my brother in law called me and said he was on his way over & he brought me an awesome gift...
Guess what he Finally Finished...
HERE THEY ARE.... ( in steel for the Prototypes, because steel is Cheaper than Aluminum )
3" Lift Blocks to be in stalled this weekend on my EF Hatch, because I still haven't installed my JRSC A6 in my wagon.
The set
The fit
Mounting bolt & lock in... Allows bolts to be replaced if ever damaged.
The EF that I will be testing them on.. It actually has Tokico Blues suspension with a 2" drop.. I am replacing with stock suspension and the 3" strut spacers... So, It should be about 5 Inches Higher...
My Hatch Photo Chopped to see what it might look like
This should be Crazy & I will post the actual build/install thread real soon..
Thought I would just share...
& yes after a little testing... Kits will be up for sale... And, Prices figured out.
The set
The fit
i like ...
i want...
I am just waiting to see how bad the camber goes out.. I have used a jack to lift the car and I think I will be right at the limit, but may have a little more available height..
Another consideration is that the 3 inch block may actually cause more than a 3 inch lift, because of where the strut meet the LCA. We'll see this weekend.
I am hoping ti Fit 205/75R15 LT truck tires on it
so i have been searching for a lower ball joint that is adjustable ...
or even an arm @ the bottom that is longer to adjust out the tire back out ..
these can be used to adjust top back in..
ive seen these on the rear of Ragenasians wagon ... looks to be able to thread out the rear lower a small amount ...
i dont have any stock UCA to compare with the camber kit. but on my prelude the stock UCA allows more negative camber adjustment while the camber kit allows more positive camber adjustment
Could make it a Wago-Utility Trailer...
im fearing positive camber in front. back is pretty easy to remedy with methods you listed, but for some reason I have positive camber on my rallywagon. 1 degree positive...and I cant understand why, but i cant get rid of it. I have to stay with stock suspension for my class, but I did try a set of those adjustable balljoints SPC PN 67320 which is supposed to correct 3 degrees of camber. Didnt help at all, but I did find out that the part is reversable. So that could work in the long run.
Another thing that could maybe work are those cambolts for the Machpearson struts to push the lca's outwards?? Wonder if anyone makes anykind of offset bushing??
I was also wondering if you could buy those extended tophats off ebay and reverse them to point down instead of up and do basically the same thing those custom pieces do??
either way, this is gonna be cool once you get it sorted.
viewtopic.php?f=5&t=12902
Derrrr, yep. thank you. Just wasnt seeing it right in mah head.
Lets see, what about regular hatch struts, cheapy ebay coilover kits with rt springs and the center cut out of the tophat for centering?? You guys got my gears grinding today, lol.
hmmmmm, lots of really good ideas about lifting wagons floating around. So weird, weve always gone down. Its exciting to go up. Sum ting different.
O.k. So I made an attempt to install the 3" spacers on the AWD Rear Struts & Holy Crap they are big..
I was over extending the Rear CVs & that was using spring compressors to get them in.. They almost came apart.
I was going to take pics, but figured, on my next attempt... I am going to try to space down the rear differential a couple inches and lower the trailing arm with spacers and longer bolts.....
I have some other plans and will be trying them shortly...
The new AWD is fun as hell anyways and I played around driving it in a dry retention pond.. SOOO MUCH FUN!
I did however notice that It will be really easy to put the spacers on my hatch...
The 3 insch spacer is going to be more like a 4" - 4.5" lift..
I need more spring compression on the car..
I may try a 1.5" - 2" spacer, which should only be about a 3" lift... I know I could have got that in there..
Just be carefull with the angle of the driveline. Too much angle on that thing and it will die, lol. They arent the toughest u-joints out there.
