here we go again, skipping.
alright, so i took my wagon out on its first trip on the big road since the engine swap (stock D15B2 replacement engine). well, its started skipping a bit after a while during acceleration. then while driving in the city at low speeds stop and go, it got bad enough to the point that it was as IF it were flooding, because it would not revf at all just started dying, and the tach was going on and off. CEL came on for a code 4 (crank angle sensor). anyways, it got over it and then did it here and there. i drove almost 100 miles today. going home on the highway it started it again, and the tach was going on and off. i turned the car off then started it again and it went fine all the way home.
anyways.... right now there is a code 1 and code 4 on the ECU.
WTF is going on? the CAS is in the dizzy, which is about a year old. i dunno what brand it is, but prolly a crappy one. (and i cant find the receipt *sigh*). is my dizzy at fault here? or what is making the car do this. this is the EXACT same problem that killed my other motor in the end. except it was WAY worse on the other motor. i dont know what it is, the car is completely back to stock now, with the exception of a Walbro fuel pump and of course the MPFI swap (which is setup in a stock way).
can anybody shed some light on my situation? because im nearing my wits end. oh, and i dont have any money haha.
add "LuckY" to nick
maybe it helps ...
voodoo doctor anyone ... ?
thanks evol911. i'll see about checking those.
both of which are in the dizzy (correct?)
so i do have a faulty dizzy. :x
http://rywire.com/store/faqdesk_info.php?faqPath=3&faqdesk_id=14&osCsid=72459706abf8c14cc9dc74e73ea24236
If its not a Honda dist, you will forever have issues with it. Honda electronics are finiky. I wont use anything other than genuine parts for anything electrical on my Honda cars. Ive seen non honda coils burn up in less than 10 minutes. Ive seen brand new non honda ignitors not work right out the box. Too many options for failure...stick with genuine parts. It will save you headaches.
D
Damn good idea. I too have had three fall off in the last year and a half. One helped ruin a motor
yeah, i had to replace the first new ones about 3 times before i got one that worked. and i would love a genuine Honda one, except they are $500+ something while this one was only $120 at the time. its only to hold me out till i can get a ZC though so whatever.
i checked the rotor, and the screw is fine. but the contact on it looks really worn-ish.
also, with the new dizzy, it started to backfire a little bit again while accelerating once :x
Get you a new cap and rotor and see what happens. It can't hurt.
oh, and i was going to do the ohm test but i forgot to get the meter yesterday from the place i was going to borrow it.
D
i tried it man, and the rotor is very tightly snug on. and i goes on and off from being bad to running fine.
Lol, be carefull with locktite man. You will need to replace that rotor again and the screws and allen bolts..whichever you have, are prone to stripping out due to not all that easy access. Theres more than one kind of locktite, just make sure you use the stuff that is NOT permanate
As for OP, gotta be the ignitor. Only thing that makes sense now. You can use one from a teg if u don't have a civic one lying around. A usual dead give away for ignitor is brownish black flakes of stuff inside the cap. Hardly noticeable unless it is REALLY far gone.
D
i have a lifetime warranty on these distributors, so i can keep taking them back, but thats just getting annoying, and all the other ones i get already look like crap. such cheap looking rebuilds :x anyways so right now im waiting on a couple other potential used ones that actually work(ed) so we'll see how that goes.
1992, a hot summer night about 2:30 in the morning, a couple too many beers, sitting at a stoplight with the system a little too loud. The car just shut off and I had to push it off the side of the road. As I was pushing it a tow truck drove by and offered to help. I had it towed home for $35 or $40 I don't really remember. I as all kind of mad when I got up in the afternoon and discovered the rotor thing.
- Mike
soon we'll have little wagons running around...
whaahaahaha...
luvyamang
i'll check the electrical connection.
ok, so i got a nice used working OEM Honda Tec dizzy (my 7th dizzy so far), BRAND NEW OEM Honda Tec Cap and Rotor...
and voila, its skipping again. code 4, crank angle sensor. i have no bloody mary idea what can be wrong.
the engine itself came from a perfectly fine running car (bam-bam's old D.)..so its not that. frick. anyone know, anything?????
