'94 JDM Shuttle Radiator
hi guys
is there anyone who knows that which radiator fits to my 94 JDM civic radiator?i checked some memner rides Haydzs' wagons radiator looks like mine but i couldnt find shuttle radiator in ebay.so which other honda civic radiator fits to my vehicle.
does radiators differ from region to region?like hot climates require different kind of radiator warmer climates require different ??
:arrow: There are 2 types of electric fans used on the wagon & Sedans.Shops will tell you there the same... :evil: They lie!It's not a big problem.You'll have to modify the fan to fit or get the right fan.The one I worked on we modified the original fan because the fan was actually quieter than the correct fan.I think the better fan had fins on it.I saw a lot of Civic Sedans that with the modified fan in the wrecking yard.If you have AC it'll be a bit harder to remove the radiator.
