Wagon Radiator support the same as hatchback and sedan?
Looking to replace a 88–91 civic wagon radiator support and driver side frame rail. Does anyone know if the radiator support and frame rail are the same as 88–91 civic hatchback‘s or sedans?
has anyone used a hatchback or sedan radiator support on a wagon?
I haven’t heard or seen anyone use them before, I believe they’re different length, if possible go and measure the two to see a difference but I think length wise it’s different
I’ll start by measuring the width. I’m not sure if the actual length will play a part being that it’s a spot welded in
I appreciate your comment thank you
So based on Majestic Honda the radiator for the RT wagon and the EX sedan are the same. Both part numbers 19010-PM3-305. So I think that would indicate that the supports should be the same, at least distance wise.
Thank you for the information.
