i got the first 4wd engine mounts from innovative mounts
13»
  • AbideAbide Council Member
    it's rt4wd in rt4wd chassis essentially its a d-series ef kit, same motor side mount same trans rear mount since thats just the one on the cross member and not on the trans. then the unique rt4wd mount that bolts onto the side of the trans instead of the top.
    top is the engine mount, left is cross member and right is tranny. no front included. got mine from go-autowokrs
    I just ordered a set and the rear and trans mounts seem fine but the engine mount does not look like it fits correctly.
    Video here: https://youtu.be/J_xc3rvds2E
    Going to call them on Monday I guess. Luckily I have another A6 from an RT with the correct mount because mine oem rubber is ripped completely. :(
