84 wagon fwd
I got a 1984 civic 5 door wagon not 4wd with a really bad vacuum leak. My buddy is selling me a d16y8 for cheap I wanna throw it in my honda. What do I need to do to do this? I don't want anyone's opinion, tellin me just to fix the leak I want to put the d16 in.
Engine, trans, wiring, ecu...probably a jumper harness. possibly mounts as i'm not entirely sure that it will just bolt in. I'm also not positive that the shift linkage will work either.
I've got an 87 fwd wagon and things just do not look the same under the hood. might just be the size that is deceiving me but yeah. There isn't a ton of info on the pre 88 wagon swaps on the site. You're best bet is probably to look through the builds and see who has a build going on one.
Go third gens!
I'd like to know some more about this... a mini me is just a tec head on a non vtec motor right? will that work with my 1.5 EW-1?
Oooo, that blows...
That is what I was going ro do befor I found my new engine. D15 pistons, and a D15 or D16 head. From what I could research it should work, just need to play with pistons and head gaskets to get the compression and figure out what timing belt for whatever head you use.
