Fluctuating Idle after warmup. ICV?
Hello i feel ashamed to be asking this because I used to be so good with sensors and where they were and what they did, I have been having problems with my 4WD's Idle after some spirited driving especially.
The car just went in for waterpump/timing belt change and i got the valve lash adjusted also-
the car will go from about 700-1500rpms while im at a stop my buddies prelude used to do it and it turned out to be the idle control valve and all he had to do was spray it with brake cleaner and re install it.
my question is where is the idle control valve and does it sound like it could be the problem? thanks anyinput will be apparecated.
bubbles. Try to flush it and see what happens.
Good luck.
me and my sick jokes ey...
worst case scenario, valvecover, gasket...
GL..
http://ef-honda.com/ben/Badidle.html
