89 rt4wd no power to fuel pump
 gsrdb
                Band Wagon
gsrdb
                Band Wagon
                    Okay I just made my account tonight. I've read the posts and can't really find what I'm looking for.
I recently bought an 89 rt4wd from an old man. The wagon has been sitting since 99! It had 110 k on body and originamotor. He said the fuel pump was bad. And he had a new one. It turns out both fuel pumps were fine. But im not getting any power to the pump. I have tested the relays. Except the one under the dash and the ignition swich. I had to run a hot from the alternator fuse to the fuel pump to get it to work. Got the cr started with starting fluid. It runs and idols. So basically I have 2 questions.
1.) Is it safe to run a hot wire from some main sorce of power to the fuel pump to get it to drive.
2.) Does anyone know were the fuel pump wire goes specifically so I can check for a short?
Now like I mentioned before this is a 1 owner car. Never been molested. Low miles and it was sold 14 years ago bc the fuel pump was thought to be bad. Turns out its just the power supply to the pump I just do t know were to go from there.. any input will help.
Thanks!
Thanks!
