Probably because there is sentimental value in the wagon he has now.. I think its pretty awesome, might be able to find parts from a donor in a pick apart..
I have the full swap all parts from a wagonist named(1988rt) its gonna be done by Friday all goes well! And yes the resonance for swap is I love my shell! And no rust! Engine bay is super clean! Will post pics and progress!
Wish i could go back in time and buy back my super clean auto FWD wagon i got some shakey.... i planned on doing an RT swap on it i even have a comeplete junkyard wagon.... grey rt4wd would be tits. good luck man
Nasty rust do to the horrible location for the batterie
masked off ready for paint
after primer, base coat, and finaly clear
comming up next how to install a typer r brake booster and master cylinder, how to use a 2005 honda civic valve cover so stay tuned in for next weeks edition how to pimp your ride
Definitely cool to see someone follow this whole thing through. That's a pretty gnarly chunk of metal you guys had to cut out. Great work, props on being one of the only guys around to have done this. Hey bud not sure if you got my PM's but I was wondering if you still wanted to sell that lip? Hit me up, you have my number.
I been throwing the idea of city lights in my wagon? And did it! hell yeah! suxsess!!
took light out lol.
i reamed hole after pre drilled hole smaller than hole to make exact fit yahh pimp:encouragement:
put knotches in used my marker light from my wagon to copy knotches. And ran wire same path as blinker n marker.Looks clean this way.:encouragement:
I sautered all wiring
I wired it from my markers.
then installed
Tell me how you really feel, also Im going to put one in with my high beam to give it the full JDM EF9 glow effect:encouragement:
ok so 1 month later my bolt weldes to the fram no good! had to weld plats to body and nut to plate then suxsess. it broke loose on me when i didnt do this.
Id like to see the progress
easier said than done in most cases.
glwb man!
Too true! I love my wagon, but part of me always wishes I had found an rt instead.
Looking forward to this build. Was considering the same on my 2wd.
this. this is exactly what you need to do. find one that somebody has wrecked and that will leave you with everything.
Do you have another or know where i could get one? My shift tower is going bad and i need a new one soon.. Sorry to threadjack
Will it be done by tomorrow? Im ready to see some pictures lol
The pieces you need
you weld them on so that you can bolt on the drive line and e- bracke handle
here is some more random pics of the work in progress
Interesting about the driveline mounting point though, i was under the impression all the chassis were the same
expecially based on your first post; i was like "yeah right, another wagon noob" but awesome that your proving me wrong..
impressed... in for more!
bseries awd? i didn't think that was possible (noob)... please explain.
took light out lol.
then installed
THANKS 4 CHECKING
