Chads Wagon Build
chadcouch
Wagonist
I going to turn my 2wd wagon in a awd! Can't wait, Also doing a Zc swap and going Turbo! A fella wagonist is doing the swap 1988 rt!
Id like to see the progress
easier said than done in most cases.
glwb man!
Too true! I love my wagon, but part of me always wishes I had found an rt instead.
Looking forward to this build. Was considering the same on my 2wd.
this. this is exactly what you need to do. find one that somebody has wrecked and that will leave you with everything.
Do you have another or know where i could get one? My shift tower is going bad and i need a new one soon.. Sorry to threadjack
Will it be done by tomorrow? Im ready to see some pictures lol
The pieces you need
you weld them on so that you can bolt on the drive line and e- bracke handle
here is some more random pics of the work in progress
Interesting about the driveline mounting point though, i was under the impression all the chassis were the same
expecially based on your first post; i was like "yeah right, another wagon noob" but awesome that your proving me wrong..
impressed... in for more!
bseries awd? i didn't think that was possible (noob)... please explain.
masked off ready for paint
after primer, base coat, and finaly clear
comming up next how to install a typer r brake booster and master cylinder, how to use a 2005 honda civic valve cover so stay tuned in for next weeks edition how to pimp your ride
took light out lol.
i reamed hole after pre drilled hole smaller than hole to make exact fit yahh pimp:encouragement:
put knotches in used my marker light from my wagon to copy knotches. And ran wire same path as blinker n marker.Looks clean this way.:encouragement:
I sautered all wiring
I wired it from my markers.
then installed
Tell me how you really feel, also Im going to put one in with my high beam to give it the full JDM EF9 glow effect:encouragement:
THANKS 4 CHECKING
