Alternator?
the problem im having is the car will stall after it is warmed up, it gives me a hard time to start, i have to give it gas for it to to stay on or else the rpms will drop all the way to 0 very slowly, i replaced plugs, wires, cap, rotor, ignitor, ignition coil, fuel filter, took the injectors out and soaked them in carb cleaner ( there working fine) checked all the fuses ( all checked out ok), checked the ohms on the injectors ( checked out perfect) replaced the main relay, no check engine codes, when car runs i hear the fuel pump working fine, took the fuel line that goes into the trottle body (dual point injection) and turn the key witout starting the car and a half a cup of fuel came out ( check out ok) when the car heats up completely thats when it dies. it feels like its studdering, when i floor the gas then it stays on... NOW THERES ONE THING I NOTICED! when i pulled the positive cable off the battery when the car was running it shut off, DOESNT THAT MEAN THE ALTERNATOR IS BAD? check the alternator fuse its fine, checked the connections to the alternator and there clean, and the battery isnt dead nor low on life... would the atlernator make the car stall when its hot or give me a hard time starting??? also i noticed when the car is warming up and i put the headlights on the rpms drop and when the headlights and highbeam is on the rpm drops a half of an rpm, after i cleaned the injectors the car was on for 10 mins and ran great no hesitation to start and then died and the battery light and oil light came on, but the battery light was very very dim and look like it was quivering, then it would go off then go on very dim....Idk wat else to do... MY QUESTION is will the alternator cause the car to do this, i just dont want to change the alternator and its something else :? its driving me insane lol any help would be greatly appreciated
were u having the same problem? wit the hesitation and studdering?
great i appreciate it!
I put mine off, and regret it. Life has been easy since.
thanks alot charb imma put a new one in tomorrow and ill let you know how it goes, i really appreciate it! i hope this is it
Read my thread for details.
Everything you explained above is what led me to replace my alt. My problem was fixed.
iight thanks bro ill try that
