Tail lights won't work, 10 amp fuse keeps blowing
What in the hell could be causing this? Brake lights work, headlights work, everytime I replace the #8 fuse in the under-dash box & turn on the lights, the fuse blows & the tail lights don't work. And the light in the dash where the speedometer & odometer is out.
have you installed a radio in your car recently
if so double check your ill/dimmer wires for correct connection
if not then just start checking for dead shorts in the wiring
good luck
The following are hooked to fuse #8:
dimmer
dash lites
side,tail & plate lites.
