C pillar braces
any of you guys run c pillar braces? if so where'd you get it from and how much?
if you're not familiar what i'm talking about see link:
http://cgi.ebay.com/ebaymotors/JDM-GUNM ... 3a5d203ffd
    Buy some solid bars, the ebay cheap stuff is more for show!
    Got mine from a civic hatch.
  • WagonAttackWagonAttack New Wagonist
    okay cool so it will work. i just used that more as an example. thanks man!
  • NZ-DB8RNZ-DB8R Moderator
    As above,
    I also use a EF Hatch one
    I just put one on mounted to the upper rear seatbelt bolts. USELESS. The points where it mounts is paper metal, i thought it would be rigid because you mount the seatbelt there. You can flex it with your hands.
