D16z6 into 89 wagovan. resistor box issue
I'm swapping a z6 into my wagon. I have all the wiring conversions done.
My last one is the elimination of the resistor box. I simply can't find it. It should be right by the brake booster. I looked all throughout the engine bay just incase, and I even looked under the dash incase it was relocated for whatever reason.
There are no signs that it was eliminated, and there are no signs it was even there.
Do 1989s have a resistor box? I would think so because you need it to run obd0 injectors... Please help?
Do I put in my motor and not worry about it... or am i going to fry injectors...
When you converted the engine harness, where did you get injector power from? Should be a yellow/ black stripe wire from the left shock tower plug.
Thanks bam
