Problems with my d16z6 wagon
well i just did some work on my wagon (replaced my clutch) and now its not starting theres a clicking coming from my main relay so i checked all my grounds they all checked out ok even added a ground! still clicking then i herd another sound it sounded like its coming from my intake manifold.... you can even feel it! does anyone have any ideas what it might be?
If you just had the tranny out, check over what you removed.
1) The battery cable to the starter (12 mm nut, ring terminal)
2) solenoid wire to the starter (smaller wire, spade terminal slips on)
3) ground wire to the clutch cable bracket (10mm bolt, ring terminal)
as for the sound its kinda like a ticking but with a kinda burr sound to it from the intake manifold.
