Idle and ECU woes
*This is all regarding a D16A6 engine which was originally automatic and still has the auto throttle body/intake manifold*
I was wondering if any of you ECU gurus know anything about the differences between a PS9 and a PR3 ECU? I know the PS9 is just the autotranny version of the PM6. I'm curious because my car acts much differently depending on which ECU I use.
With the PS9, the car will not idle under 1200rpms with the EACV plugged in unless the idle adjust screw is completely screwed in. I'm assuming this just means I need a new EACV. With the EACV unplugged I have to readjust the idle screw to get the car to run, and I can get it to sit right at 850rpm.
BUT, after readjusting the idle and unplugging the EACV to get 850rpm, the car is SO jerky when I try to hold a steady speed or get on or off the gas quickly, it feels terrible and I can tell it puts terrible stress on the drivetrain. It is also jerky like this when I am using the PR3 ecu. Does this just mean my TPS is probably shot?
So onto the ECU differences... When I run the PR3, I cannot get it to idle under about 1000rpm with the EACV plugged in. I would prefer this since it is a lot lower than I can get with the other ECU, but every time I get off the gas now, it pretends I didn't get off the gas for about a second. So when I shift I have to completely let off the gas about a second before I clutch to make it smooth, FUCKIN WEIRD!
Anybody got any ideas? Do I just need a PM6? Or just a new EACV?
TIA,
Thomas
TIA,
Thomas
I didn't think the EACV was necessary to retain regular driveability, I have seen a lot of Y8's with it just removed and blocked off, but I doubt they were having the jerky/touchy throttle problem that I'm having. To me that part of it really points to the TPS, even though I thought that little dashpot on the throttle body was there only to prevent this kind of problem when you let off the gas abruptly.
So I guess I just need to check the voltage on the TPS and see if it is dead/needs to be adjusted. Then if that's OK I'll start on the EACV. Before anybody asks, yes I have taken it off and cleaned it already, didn't do anything.
