Bulb model number for lights and locations [USDM]
Hi All, I’ve been trying to get a together a list of bulbs and model numbers. I’m a REAL big LED fan, clean and bright as hell has been my thing with my past two cars (Prius and Evo). However looking at the bulb replacement guide on Sylvania’s website I’m slightly confused as to the location and ‘normal’ operation of each light. And it doesn’t help that most of my bulbs are blown own and not working. After some testing with the surviving functional ones I think I’ve got it down, but need a little help and clarification.
Please refer to the pictures as well as the number guide. Down below I’ve compiled and cleaned up the list of bulb part numbers required. Please feel free to add some items to his if I’ve missed them. I also would like to know if I have the operation of the signals correct. Please feel free to correct as I will update the first post.
Front Picture Front:
1. Turn Signal??? [Need Clarification]
Operation: Light comes on when the ‘parking’ [middle selection] is selected on the lights stem. Additionally this light counter blinks with the turn signal when signaling a turn or when hazards are on.
2. Side Marker??? [Need Clarification]
Operation: Light illuminates and stays constantly on when in parking and or full low beam mode [3rd selection on light stem]
3. Low beam
Operation: Light comes on when in full low beam mode [3rd selection on light stem]
4. High Beam
Operation: Light turns on when ‘high beam’ function is selected
5. Turn signals??? [Need Clarification]
Operation: Light blinks counter blinks when a turn is signaled. Illuminates on all three light modes.
From Picture Rear:
1. Rear Side Marker??? [Need Clarification]
2. Rear Turn Signal
Operation???: This turn is amber in color and blinks when a turn function is selected form the light stick
3. Parking Light??? [Need Clarification]
Operation:??? [Need Clarification]
4. Brake/Stop Light
Operation: Brakes are illuminated to their fullest when the brake pedal is stepped on. However when the lights stem selection is at ‘parking’ or ‘low beams’ these lights will be illuminated.
5. Backup/Reverse Lights
Operation: Illuminate white when a car is put into the reverse gear.
6. License Plate Lights
Operation: Lights illuminate when in low beam mode [3rd selection on light stem]
7. Third Brake Light/High Mount Brake Light
Operation: Similar to that of the stop lights. This light is illuminated when the brake pedal is depressed. However unlike the stop lights it is not illuminated by default when in ‘parking lights’ or ‘low beam’ operation.
Bulb part numbers per Industry standards
Taken from Sylvania website
1989 HONDA Civic
Low beam headlamp
9006
High beam headlamp
9005
Cluster (1989)
2721
Parking light
1157
Front turn signal
1156
Rear turn signal
1156
Tail light
2057
Stop light
2057
High mount stop light
921
License plate
168
Back up light
1156
Front sidemarker
194
Rear sidemarker
168
Dome light
DE3022
Trunk/Cargo area
DE3021
Industry Common Part Number Cross-Reference. Listed on the left hand side are common bulb sizes/sockets and on the right are compatible reference numbers. For example our clusters use a 2721 sized bulb. However this can be cross-referenced to the standard 74 size. Meaning if you buy a 74 sized bulb it will fit in your cluster.
Common Part # Cross Reference #'s
1157 1016 1034 1076 1130 1154 1158 1493 2057 2357 2397 7528
1156 1073 1093 1129 1141 1159 1295 1459 1619 1651 1680 7506 7527
7443 7443 7440
7440 992A *7443 bulbs will work in all 7440 applications
194 147 152 158 159 161 168 184 192 193 259 280 285 447 464 555 558 585 655 656 657 1250 1251 1252 2450 2652 2921 2825
3157 3057 3155 3357 3457 4157
3156 3456 4156 *3157 bulbs will work in all 3156 applications.
57 1895 53 57 182 257 363 1445 6253
74 17 18 37 70 73 79 85 86 2721
921 906 579 901 904 908 909 912 914 915 916 917 918 920 921 922 923 926 927 928 939
211 212 212-2 214-2 6413 6429
6418 3423 3425 6411 6423 6461
3175 3021 3022 6428 6430
