No start/crank - Code 8
After driving the car down my driveway, then back, shut it off. About an hour later I went to move it and it wouldn't crank at all. I'm getting a Code 8, which is TDC/Crank sensor.
So after following the troubleshooting flowchart in the manual, I've ruled out distributor, ECU, and for kicks main relay (had a buddy over with same stock DPFI set-up and my stuff worked in his car and would start fine, his in mine and still same no crank). Luckily I was able to do this as everything I found on this problem is fixed by replacing distributor. Well not the case here.
I'm starting to think there may be a break in the harness somewhere, but don't really know how to correctly test for resistance and find the break.
So does anyone have any recommendations for doing that or other ideas of what it could be?
maybe?
