Aerial help, please
I am trying to put a nerw aeriel into the shuttle, got the replacement one no sweat out of the shit one, and pulled my one half out and snapped the cable. got the pieces out, but now I am trying to get the new cable down the hole and into the cabin, I have taped the new cable to a rod an stuck it down but cant find the access hole so i can pull it through, I have removed the fuse box an lower dash cover.
any fresh ideas?
any fresh ideas?
Even using this method, Stephen and I spent over an hour changing his last weekend. There's a choke point about 3/4 of the way down the windshield post that seems like a wall. The trick is to pick up on the wire at that point to get past the pinch.
Tricks:
You need a wire or string run through there first- something to pull the lead through. The path isn't exactly straight, and you'll never be able to push it through there. Use a straightened coathanger to push down from the top, or maybe a piece of electrician's fish tape. Once you get that thru, use it to pull a wire or twine back up. Then tape that to your aerial lead and pull it back down.
Some silicone spray, or liquid soap- some lube will help.
I don't know if this will translate to your RHD car, but open the door and look for the black rubber tube that goes from the door post to the door- it carries the wiring harness for the door electrics. Pop it out of its hole at the car end. You should be able to see all the way into the car. That hole corresponds to the hole on the inside of the post where the aerial wire exits. You can stick your fingers in there to help guide the wire.
Clear as mud, right? Good luck!
edit: nevermind, I see it's on the right (wrong) side :P
Good luck! I am probably going to do this to my wagon soon.
just maybe...
