sub box help, new pics
ok so i just picked up a alpine type r 15" sub, and i was looking up sub box size requirements and it says a non ported box has to be 1.75 cu feet, and a ported box has to be 2.90 cu feet, so i droped out of high school in the 11th grade and i need help converting both of thoose into a box plan thats in inches, i have no idea how to do that but i know that the 1.75 cu feet and the 1.90 cu feet are mesurements of voulume so im assuming that thoose are the inside mesurements not the out side diamentions any help would be great and yea i know bad spelling, thanks- pat
okay that may be hard to follow.... look here http://grapevine.abe.msstate.edu/~fto/t ... l/box.html
Just make sure you use inches or feet, not both. And you can put your result in and leave your depth blank.
? power handling...
? displacement
? tune @...
and such...
if it is not that much to you
go free to air...
...for the time being
good luck
keep us posted
Do it right and you will be happier with the outcome
and also true...
...you caught me
i installed rear tweeters, against the headliner
Also the Polk Audio Sub came with a nice diagram for the box plans (I of course didn't follow it
Nothing professional but it works
Yes a cap is a must. nothing like having your alternator die on you in the middle of where ever.
