different wiring for EF cluster?
So I know that if you stay year specific that an EF cluster should work the same. I have an 89 wagon and I am trying to use an 89 EF SI cluster. When I plug it, it does not work, it seems like the speedometer is working on the gas and the rpm is working on the heater. But the RPM and Speedometer just does not move. Also, the brake light only comes on when i turn the lights on and the Highbeam stays on even though the highbeam is not on. Can someone tell me if I'm doing it wrong??
different pinout
no one with a flow chart of the two
second, and MOST IMPORTANTLY.. that IS NOT an '89 cluster. that most definitely is a 90-91 cluster. sorry mang! but thats your problem
88-89 cluster looks like this:
no-go-nuts
who wants some?
oh my g...
! he shoots...
!!! HE SCORES !!!
AND the crowd goes wild...
heehaw
! go skinny ! go skinny
Whats that out of!? Never seen that before
btw, the 90-91 Civics STILL use a speedometer cable.
that extra plug on the back, who knows what its for because i had a cluster with it and just didn't plug it in, nothing bad happened ever
just get a cluster for an 88-89 and forget all the headaches
right. its an EF with an s2000 gauge cluster.
Seems unnecessary, especially from a 3 month old :roll:
There is an opel digital cluster that is sqare. I need to get some pics of it. Might fit pretty good under our bezels.
http://www.marklamond.tsohost.co.uk/pro ... /order.htm
Here is the man to do it. prices and everything you ever wanted to know about swapping the cluster. For the $500+ its gonna cost you, you could do a custom cluster of autometer guages.
Back on track though. How is the cluster swap going? Did the info I pm'ed you help?
Live rates at 2009.05.01 08:32:38 UTC
170.00 EUR
225.081 USD
Euro United States Dollars
1 EUR = 1.32400 USD 1 USD = 0.755284 EUR
So say $225 plus the cost of the cluster, plus the cost of shipping both ways. Then it has to sit in customs both ways. So figure its gonna take you atleast 2 months to get it sent off, converted, then shipped back and wait to clear customs. Wish I had the money to do it.
Edit: looking over ebay a cluster from a 2000-2003 will run you anywhere from $75 to $200. I couldnt find a 04 and up.
the Opel/Vauxhall digital dash is from an Mk2 Astra GTE
as said, the EF9 and EF8 (siR) have VSS digital speedo's, where as all the rest are cable
