Air control
I've been getting really frustrated at my wagon...and even though it isnt running right now i want to go ahead and fix it.
Half of my air control cluster is broken, the fan speed 1 and 2 dont work.
and the air direction switch does not work either.
Will any of the air control clusters work from any 88-91 civics?
Air direction switch?? Are you talikin' about the slider?If so follow the cables to see what came loose or broke.
My blower is really weak and I need to fix it, is my best bet just to buy a replacement blower for a Civic? Or is it possible to swap in an Accord blower to try and get a little more power?
i would check inlets, ducts/leaks, clean blower/lubricate under glovecomp.
not that much hassle before buying
