installing a subwoofer???
My 91 rt4wd is lacking in the stereo department. I've got the original radio and the 2 front door speakers. I was at Big Lots the other day and happened upon a Roadmaster 6.5" subwoofer tube thingy for $10. How do I go about installing it? Do I need an amp or can I just hook it up to my current radio? Thanks!
found this one here. 15 bucks
http://www.goodwilltoo.com/browse.cfm/4,1097.html
well your gonna need a few basic parts to get this to at least sound decent.
even tho its small you will need an amp.
it says 200 watts peak but i dont know the rms.
if you get the rms number which i will assume it should be below 100watts continues or something like that.
get an amp that is about 100 rms continues watts or if you plan on upgrading in the future get something way more and you can always turn down the power on the amp.
- amp
- wiring. for power, ground, remote, RCA cables
- connectors
- inline fuse for power wire
that should be it for the most basical part of it.
stores around you like circuit city or best buy should have a basic kit all prepackaged for installs like this. it should have everything you need so you dont have to worry about missing any part. they run pretty cheap on the price too.
the kit has a few level so prices can go higher.
each kit will contour to different needs of the installation.
for example one kit will contain more wires and cables. those are for people who plan on installing more then one amp.
another will be for someone who wants to run a very high wattage amp so the wires will be much more thicker in gauge.
and it goes on from there.
so that should get you started on the right direction
good luck on the install. its pretty fun when you get it down.
What kind of amp do you have? If it is a cheap amp that can be a source of your problem. Swap amps if you can and see if it changes.
You could try and ground the rca outputs on your radio. Strip some copper wire wrap it around your rca ouputs and ground it to the chassis of the radio.
Make sure your RCA cables are shielded.
Make sure your AMP is grounded to good solid metal and the ground point is free of any rust or paint.
As much as Id like to go all out and hook this wagon up with nice sound, it ain't gonna happen.
On that note, anyone have any good recommendations for a good quality, yet inexpensive upgrade from stock? Head unit? Amp? Rear speakers? Nothing crazy but definitely better than stock. I think I may have some 6" speakers I pulled from the rear of a wrecked CRX I bought for parts a few years ago that I can use. They might even be Sony Xplod ones if my memory is correct.
Thanks!
All those companies like pioneer, kenwood, sony, jvc have cheaper lines of stuff that are decent and won't break the bank.
i have pyramid amp and visonik subs... i might ask someone that has an amp and see if it does the same sound. i will try to do what you told me. and yeah the ground is a non rusty place. thanks
