Electric Load Sensor?
Ok, well I keep getting ECU codes.. It's two long flashes.
I thought it was the secondary 02 Sensor, but I changed it with a new one and it still comes back..
According to these charts its a electric load sensor:
http://hondaswap.com/reference-material ... des-29109/
Where is this thing located? Whatever it is it is making my car bog and such.. Could it be a bad alt.. Maybe locking up and stuff? Cause my lights are dimming really bad when I let off the gas and I can be going down the road sometimes with my radio on like 20 and my lights will dim with it..
So what the hell?
So what the hell?
So I bought a high output 130 amp alternator.. I figured 60 amps more couldn't hurt.. lol
It sounds stupid i know but this can also be a loose battery terminal. I had a loose terminal once and the inertia would make it disconnect ever so much and the electrics would switch off and back on again.
I had the same thing goin on with my 91 Jetta coupe. After running a ground strap from the battery directly to the frame, everything works great.
