91 wago- awd to fwd
So, quick question. I was wondering what would need to be done to drive a 1991 rt4wd wago as fwd? Do the rear hubs need an axle in to hold it together or can I just pop the half shaft out of the diff and hub and be fine with the hub?
I ask this because I haven't stuck my head to look at the inside of the hub to see if theres anything that holds the bearing assembly in or if it relies on the axle nut/shaft. Just want to drive this thing for now like this.
    Check icon1.png Engine & Drivetrain Quicklinks
    Under that check:
    How to disengage four wheel drive
