UPDATED: B20 bogging.
Hey Fellow wagoniers, i previously post about my b20 wagon, bogging and not puling, and being as peppy as it was before. I did fix the bogging, i cleaned the injector clips and the tps and tps clip, and new battery terminals, and that helped a lot, with the bogging and the idling. And about it pulling harder(from off the line and in low rpms) like it was previously, that did not help much, it seems like its reving real loud but not gaining much speed.
This is what im thinking about doing
-new cap,coil, rotor
-new throttle body
-taking tps off and cleaning
-fuel filter
-air filter
-spark plugs(if bad)(if not check gap)
Any help would be extremely appreciated, thanks guys!!
  • i wonder if your cat is clogged. if u have a laser thermomete,r maybe see if its a noticeably different temp before and after the cat, when its running.
