what shifter cables for k swapped wagon
I'm in the middle of putting a k24 into my wagon and have it mocked up in the bay currently. The stock wagon cables won't work because one is a bit short and the bracket to end length is different. Before I start hacking shit up does anyone know if other k series cables might work? The transmission is 4wd from a element/crv if it matters.
  • PoozMcgueePoozMcguee New Wagonist
    http://vtec.academy/budget-k-swap/
    Found this handy for a genral parts list of what's needed, Hope it helps.
  • GonisGonis Band Wagon
    You need to change shift box to non-inverted type. I think these can be found in RSX, or H/F series honda models. I used H22 Accord Type-R shifter box, and made custom cables. I heard that using RSX box with cables will not require any modifications (except for shifter mounting points).
