86 4wd engine swap
Hey everyone. I have an 86 4wd with the 6sp tranny, and the engine is on her last leg. Anyways, I've done some searching and can't find any solid answers on engine swap compatibility. Was wondering if all carburetor'd E series would drop in while keeping 4wd? I saw a few threads mentioning the ZC was a direct bolt on to the 3rd gens. Again, can I swap a ZC and keep 4wd? If anyone here could steer me in the right direction, or knows the answers it would be greatly appreciated.
Thanks,
Dane
Thanks,
Dane
I'm about to buy a -86 with a 1,5l engine, will a ZC swap be possible and still keep 4wd?
http://hybrid.honda-perf.org/tech/zcinfo.html
86 has been sitting for 4 years. Just bought a 87 browntop integra to be the doner car for the swap. Thread officially necro'd
Buenas, buenas creo que he llegado algo tarde para comentar esto pero bueno a quien lo lea y quien se anime en un futuro a hacer el proyecto, les cuento que no lo hice pero lo compre asi, tengo un wagon 86 4WD con un motor D16Y7 de un civic 98 y funciona de maravilla, el swap no paso a mas de colocar el nuevo soporte del lado izquierdo al motor y adaptar el soporte trasero, el motor tiene un leve grado mayor del de fabrica de inclinacion pero asi lo compramos y anda de maravilla
