Weird side-marker problem, no flash... unless the hazards are on... sometimes
So I have a problem... I just can't let her go...
Anyway, the current problem is that the side-marker lights that are supposed to blink, only blink when the hazard lights are on. When the turn signal is selected, they will flash once or twice and then remain either on or off, depending on whether the parking lights are on or off, without flashing. They used to flash more times before they got to this point, but the problem has gradually progressed from several flashes to now just one... and sometimes not even one.
Compounding details:
The parking light switch turns those same lights on and off just fine.
The same lights flash just fine when the hazard lights are turned on.
The signals in the front bumper, and the rear signals all work just fine, regardless of what the side-marker signals are doing.
I replaced the "side-marker control relay" last week.
I replaced the turn-signal relay recently.
I've done LOTS of screwing around with the wiring, and had to wire in some new switches to bypass the partially broken multi-function switch (so I could have fried something in the midst of said screwing around).
The screwing around was BEFORE I replaced the relays, so any problems caused by the screwing around shouldn't have affected the relays.
AAAAAND I can't find a decent wiring diagram for the lights!
What else could be wrong? Thanks!
So, it seems like the flasher/relay can't be broken because they DO flash when the hazards are on. It also seems like the controller shouldn't be bad because it's new, though I wouldn't entirely rule that out. SO, my inclination is that there's some controller that dictates how and whether the side-marker flashes. They flash in sych with the bumper light if the parking lights are on, but they alternates from the bumper light if the parking lights are on...so something makes it do that. Whatever that is, it's the only thing I haven't found and screwed with or replaced yet.
Thanks...
Also, I think you will find that a real factory service manual for your car is VERY useful.
Anybody have a known-good ICU I can buy...for less than the car's worth?
