need help dpfi to mpfi asap
Im in the middle of the swap and ran into a wiring issue, im trying to figure out how to wire the resistor box, ive reaserched how to wire it and im a little confused, the problem im having is how to run the single blk/ylw wire from the resistor box plug, i found a posting that says to just run the single wire to a15 on the ecu, and another says to splice the dpfi injector plugs and run the blk/ylw wires to the single wire on the resister plug, can i just run the single wire to the ecu, or do i splice the wires and run it to the resistor plug, and do i only use one blk/ylw wire from the dpfi injector plug or run the 2 blk/ylw wires from the injector plugs, please someone help, thank you
  • 1.5 ef1.5 ef Band Wagon
    Ran the single blk/ylw wire from resistor box to a15 on the ecu and it worked fine
    Good job. Funny , but any of the ways you mentioned would have worked.
    Thanks bam-bam, thats the only part that was confusing
