Compressor Bracket
I'm looking to install an AC system on my 88 non rt wagon. I have everything but the compression bracket / idle pulley.
I see posts of an item you can buy if you swap to a b series but what can I use for my stock d15 motor? What cars are interchangeable for that part?
I know that I need the proper matching compression bracket for the right AC compressor. I can always swap out my current AC compressor if it's not the right one for the bracket. I'm yet to install it so swapping it is free.
Any suggestions would help. I've checked ebay but I don't want to risk buying a used oem part off another car if it won't bolt up. I'm so close to having AC but sooo far without this part.
Thanks.
-Dre
Thanks.
-Dre
