Broke my ventilation system
So the other day I slide my ventilation too hard (I heard a snap) and now air is coming out from all dashboard vents (windshield defrost, upper vents, floor vents, everywhere!). I think I snapped the air tunneling inside the dash. I can hear the fan/ air is blowing strong but little to no air is coming out from the upper vents, with being floor vents having the most noticeable air coming out then windshield defogger with less air push.
My only problem is I can't focus air where I wanted to be. It was a cold night and after 10 minutes ride on the freeway the cabin is still freezing cold but instead the whole dashboard is pretty warm. I think the air is just trapped inside the dashboard and doesn't circulate the cabin.
Is there a replacement for my ventilation system?
I'd pull the HVAC panel to see just what's going on there. Pull the glove box, check the linkage on the blower itself. Pull the center console out so you can see the linkage on the heater assembly and see if you can spot anything that's disconnected or broken. With luck it'll be something with the linkage and you can likely fab something up.
If not you're probably looking at replacing the entire heater assembly, or at least pulling it to find out what happened inside.
