Headlights shutting off
As of late, my wagon has learned a new trick. two days ago when I was leaving work, my headlights cut out for a second, then came back on. A few more feet down the road, it did it again for a second, then came back on and stayed on the entire ride home. It's been raining a lot as of late here in MA, so I figured something got wet and had to dry itself out. Yesterday it did it again, only this time, it did it a third time once I pulled into my driveway so my theory of something getting wet and needing to dry out is bust. I've checked all my grounds, as I just changed the timing belt the other day and had to disconnect the ground that goes to the valve cover, and it seems fine. The gauge lights stay on when it does this and I have no idea if I lose my marker lights or taillights. Anyone have any ideas as to what this could be? Possibly related, but maybe not, my wipers sometimes work when on intermittent, and sometimes don't. When intermittent doesn't work, if I just turn them on, it works fine. The windshield sprayers also stopped working, yet the rear glass sprayer still works fine. Could this be a bad headlight switch? Is it a combination switch with the wipers?
