Install 88-89 corners on 90+ Wagon/Shuttle
Remove the original corner light receivers (they are inserts, not screw holes).
Install the 88-89 fender inserts.
Keep the original receivers in a safe place. The 90+ corners look a hell of a lot better. Once I come across a set I will install them.
Now you should be able to test fit your 88-89 corners. A little bit of trimming might be required, it becomes obvious when you attempt to install them. They aren't the best fit but this trick will do if you're in a bind and don't have matched parts.
    Usually people go the other way :p
    Haydz wrote: »
    Charb wrote: »
    Yep. It's only to help out those needing to mix and match. I'll get some 90+ corners soon. Some bastards from overseas are pushing up the local prices. :P
    Truthfully, the headlight buckets need to be changed to really fit the corners.
    The fenders are still different enough to require minor trimming of the pegs. The result of this change leaves maybe an extra 2mm between the headlights and corners.
