Car runs WAY out of timing? Like 1.5" CW of the needle...
I finally found someone to reassemble the engine from the boxes and bags of parts the guy who took it apart left me with. He's never worked on a Honda before, but has a lot of experience on many other engines. He took his time and did a pretty thorough job, and the car seems to run decent. He set the mechanical timing but only set the advance by ear. I bought a timing light and followed the manual and the thing is- the timing marks are so far off that I can't adjust the distributor enough to get them even close. They are a solid 1"-1.5" away from the needle in the clockwise direction.
What. The. Hell? How does my car even run?! What could be wrong here?
IT could be off.
Are you sure you are using the right timing marks?
Is the right crank pulley on the car?
Mark
