Innovative motor/transmission mount inquiry
I'm trying to find some decent motor mounts that won't vibrate my fillings out. In searching around it seems that people have said Hasports are way too harsh.
So I'm looking at these sets from Innovative
Transmission mount
19121
http://www.innovativemounts.com/ProductDetails.asp?ProductCode=19121
Motor Mount Kit
19151
http://www.innovativemounts.com/ProductDetails.asp?ProductCode=19151
The wagon has a ZC motor but from what I've read these should work on it just fine.
Has anyone run these mounts, and can confirm. Or anyone comment on the amount of vibration they get from using them. I'd like the motor and what not to be so squishy in there but I don't want to rattle everything loose if I can avoid it.
Cheers
Transmission mount
19121
Motor Mount Kit
19151
Cheers
Maybe try filling your OEM mounts with Sikaflex?
I'll have to check the Sikaflex and see what the shore hardness on that is. I found some Tremco Buff Vulkem 116 that does have a 40a hardness and that can be found here in the states plenty easy at Home Depot or even on Amazon.
I'll see what others, if anyone, weighs in on, but for the price might just be better to get some fresh OEM mounts and then fill up those gaps.
Depending on how horrible it is to change these out I might do a video test of how they are now, then with some fresh mounts, then fresh mounts filled. Set a cup of water or something on the engine and just see how much it vibrates it. Jurassic park style testing.
Thanks for the quick reply and input.
http://www.preludepower.com/forums/showthread.php?t=304505
