91 civic wagon wont start when hot HELP!
PNWagon
Band Wagon
so my 91 daily driver is being kind of a pain in the butt. She will start perfectly when shes cold but as soon as i drive and get her up to running temp and shut her off I have to wait half an hour before i can start it again. it also happens when its a hot day i dont even have to drive it and the sun will warm her up and itll just sit and crank over but will not fire up. with summer and hot days coming up this will become a problem so im trying to fix it asap. Ive heard that it could be the relay behind the hood pop lever but im trying to get some legit answers so i can for sure fix it. can anybody let me know what they think is going on?
thanks zach
thanks zach
It's a fairly expensive little part, like $75 - $100, so if you can try to borrow one from a friend's running car, I'd try that first!
I'd try to borrow someone's ICM first, (or swap their entire distributor if its the same motor), and see if that does it. If its not anything in the distributor, then pull the main relay out (its held to the driver side kick panel with a ten mm bolt, and its WAAAAAYYYY up there!). You can pop the cover off and look at the solder joints, usually you can see if they're cracked. I pulled my buddy's Main Relay out once and went over all the joints with a solder gun real quick just to melt the joints back together, and put it back in and it worked fine. Just be careful not to actually melt the solder enough to run out of the joints! If you aren't comfortable with trying it, you can just get a new one, lol. But hey, free fixes are the best fixes!
True, the ignitor can have similar symptoms, but you said it happened just from sitting in the sun, not running. To confirm, do what has already been suggested and listen for the fuel pump priming at key-on.
just above the hood release handle. next time your car won't start, bash that area with your fist and it should fire right up. go to the wrecker, grab a new one.
So for all of the previous answers with Main relay, you are correct.... for me anyway.
Good Luck
