Chipped ecu
what is a 90 fwd stock ecu ? and where is it located. how do you tune it?
  • the dpfi (2 injector engine dx)ecu is the pm5. the mpfi (4 injector engine si, and rt4wd) uses the pm6 for 88-91. the computer s located under the passenger side carpet, where the firewall meets the floor. there is a plate usually a goldish cover on top of, being held on with 4 10mm nuts. as far as tuning, the first thing i would do is convert to mpfi. from what ive heard you cant chip a obd0 computer, so you might want to consider converting to obd1.
