Where to order new Crank Pulley?
I had to trailer my car to the garage and have them air impact the crank bolt out. The pulley doesn't have the hexagon shape for the tool that stops it from spinning since it's an '88. I want to replace it with one that does. Where can I order the correct pulley from?
http://www.hondapartsunlimited.com/index.php?p=home
http://parts.sonshonda.com/
http://www.hondapartssales.com/lisle/jsp/catdisplay.jsp
http://www.hondaautomotiveparts.com/
I personally have had great luck with the first two sites but I am sure they are all great. Compare a few for prices and shipping.
If you use a later model crank pulley the P/S pump belt will be different. OBD0 uses a V belt and OBD1 onwards uses a rib belt. You can fix this issue by sourcing a prelude OBD0 P/S pulley i think?
