HOW TO: 4WD to RWD
Last time in the garage I pulled one front driveshaft out and went for a drive. Wagon is basically RWD, but I absolutely do NOT recommend driving like this.
Viscous coupler is probably suffering somewhat, also the diff and mounts for it are not made for RWD only. But it can be done and I did a doughnut on gravel, feels awesome :cool:
I would recommend deleting the viscous coupler and getting some better mounts made for the rear diff. Maybe a stronger diff from an old BMW or something.
I don't know if anyone already posted this, but though it wouldn't hurt
But, you could always post some pics of it in action.
http://www.civicwagon.com/showthread.php?7310-Jaker-s-ride
And just so people dont get a stupid idea like this. Do not just yank your front axles out and think you can drive.
edit - cant seem to find the details on the actual setup he had as I didn't see it in his thread...i'll do more digging.
Thanks 503Wagon, will have a look.
http://www.youtube.com/watch?v=SMViKVxitYI
here this might help. this is how i did it
RWD: front axle plugs, made from old broken axles. (the axles are hardened steel, you need something strong enough to cut. I used a band saw, it took forever.)
1. disassemble the axles.
2. clean off all the grease
3. cut off as much metal as possible from the donor axles. basically cut off enough to make a plug to hold the wheel bearings together.
4. tighten the plug with the axle nut, torque it to factory spec with the car on the floor to prevent the wheel spinning
5. make one plug for the trans. this one is to keep the inside of the trans clean, the c-clip on the axle end will hold this plug in place. the other side has the half shaft left in place so it doesn't need a plug.
I really need a little more power to do this on dry pavement and also LSD would help too. I drive it daily.
