just found some rust
just like the title says, i found some rust on my wago. It was bubbling from the inside, behind the paint. Didnt know it could do that. Im not done clearing out the rust but when i finish i dont know how it could repair this. Can i use body filler? Any tips or info will be greatly appreciated.
345.jpgq
    I am still in the middle of this problem! Excessive amount of body filler will crack and fall out over time. I am going to have some new metal welded in, then treat the affected areas with POR-15.
    http://www.por15.com
    From there I will use body filler to smooth out any remanning imperfections. Thread I started
    http://www.civicwagon.com/showthread.php?16929-Be-Advised!-Tail-Light-Area-Rust-May-Be-Lurking!
  • VladiVladi Senior Wagonist
    Most Honda rust comes from the inside, I think you just have to get a quote from a body shop or a friend who can weld. Cheap fixing is only making things worse in the future.
    So, is this a build thread?
  • el_wagovanel_wagovan Band Wagon
    I was thinking the same as well. No its not a build thread. Havnt started anything up yet. Soon though
    el_wagovan wrote: »
    This place is for build threads.
    Post in the bodywork section if you're posting about body work.
